Key Control icon Key Control — Assign scripts to any keyboard key (press/release), map arrow keys to movement controls; activates when the control has focus (green). Try it →
Wowee Mips Robot
So, I have finally got new notebook computer, a Dell with Windows 7 on it. Even downloaded latest ARC. Has anyone had luck with trying to control that new Wowee MIPS robot. Im just finding out it requires Bluetooth. Sadly I'm unable to get the Iphone APP to download either, so I cannot test anything that way. Im assuming I need a Bluetooth adapter, so any suggestions one one?
Thanks!
Here's the release notes for the update which included the MIPS control.
If it uses bluetooth then yes you will need a bluetooth adapter on your PC provided this is how it is used in ARC - there is no mention of any modifications required for use. However DJ did state that this is the first thing which uses the UART port (unless I have misunderstood).
hi robohappy
can you download the app thru your notebook?and download from there to your phone?
Well, I was able to download it to my iTunes app, but still unable to download it to the phone.
i think you need to download from itunes to your pc.then connect your cell to pc whit cable..
There are a ton USB Bluetooth adapters on eBay.... I have something very similar to this Bluetooth and it works perfectly....
yes i have anycom.
The mip is controlled by the ezb v4 only and uses the uart peripheral port.
We will eventually have a tutorial:)
Oh ok, Thanks for that info DJ, and to everyone with their input. I did discover this new laptop does in fact have built in Bluetooth, and it can even pick up my Iphone. Have been able to download the Iphone app to my ITunes on this pc, just unable to get it to transfer over to the phone. I do have a call into the Wowee people for about this too.
