Servo Pad icon Servo Pad — Drag mouse or finger as a virtual joystick to control pan/tilt x- and y-axis servos with configurable ports, limits, inversion, and backgrounds. Try it →
Wowwee Rovio Cgi Commands With User Privilege
Hello,
I'm trying to control my WowWee Rovio through httpget cgi commands with EZB scripts manager and so far it works but I can't get it to work with the user account I have set. Since it's connected to the Internet it's unimaginable to use it without user security.
For example I can get it to go home and dock with the following command :
httpget(https://192.168.0.142/rev.cgi?Cmd=nav&action=13)
But it works only if I deactivate the user security feature.
I tried to input user and password as follows :
httpget(https://192.168.0.142/rev.cgi?user=USERNAME&password=PASSWORD&Cmd=nav&action=13)
but it doesn't work. I must be missing something, I guess.
I'm using this documentation (below) to find out the solution but I can't find an answer to my question, perhaps and probably because I don't understand all the grammar in cgi commands. So if someone knows out I could work this arround, that would be great. I've been looking since yesterday now.
https://www.wowwee.com/static/support/rovio/manuals/Rovio_API_Specifications_v1.2.pdf
Many thanks, Elfege
PS : since I already pay for a fix IP address I'm very relunctant to use a DynDNS account.
The one I have seems to be docking just fine. Makes some strange moves but always seems to get docked. Oh except for the time I had it on the coffee table and the battery got low so off it went to self dock. Needless to say was unable to dock after landing on its top. I have successfully breadboarded a room 9 module using a NE556 timer. Still working on an enclosure with a lens so it will work much like the Rovio base.
But still have not figured out how the navigation actually works to the point where I can start coding it in ARC.
#18
Ah so it decided to roam off the coffee table by itself? unpredictable little guys.
The grandson (age 6) told me I cannot rip this one apart like all the others. He loves remoting in from his tablet and spying on Nanny and Papa. Have turned off the authentication so I can access it thru ARC. I forgot about the wheel encoders. I could use them in my calculations for navigation position.
@Alan Have you used the GetMCUReport() to check if the encoder count is changing for the read wheel? /rev.cgi?Cmd=nav&action=20
there is on robotcommunity.com a topic about these rovers. it seems they have very cheap wifi card build in.most of users change, the wifi card with a more exspencive one to solve the problem. if i understood ,the rover use wifi for docking?
#21
@ nomad, no they are not, docking uses a combination of the northstar system which is 4 IR dot projected onto the ceiling and a IR led that blinks at a certain frequency right above the dock, between these it has some kind of formula or scripting to back into the dock when battery hits 30 percent.
#22
the wifi module is a pci express module just like a laptop.
#23
I have not yet. I am still just playing around with the built in web interface. Haven't had a huge amount of time to use it yet, but that is a good idea to try.
Ooh. I didn't realize that part. I'll have to check and make sure that IR LED is functioning. Maybe it isn't seeing it. It seems to line up with the ceiling dots, raises its head, but just wiggles around without backing up and, then after a minute, it wanders around a bit and lines up again. It could be that it jsut isn't seeing that LED.
