Graphy icon Graphy — Plot live data with ControlCommand scripts: multi-series charts, many chart types, legend toggle, add/remove series, export graph data to CSV Try it →
Not sure, it's as funny as how it can be explained to you what to check for above but still have the question asked I guess...
Ensure you are running the same version of ARC on both PCs. Ensure you have the same EZ-Bits sync'ed.
I would suggest re-syncing your EZ-Bit library.
However it still stands that the arm can attach to that part 4 different ways. Following the instructions and calibrating correctly will result in a perfectly working robot no matter if the shoulder bit is at 0/180 or 90/270 degrees.
rich
i check the libery.as for the jd brothers they work perfect. i will post video later
thank you
dj
i saw some diff pics and i thought ,whoops this is wrong. averything works great now.
thank you
