Sound Servo (EZB) icon Sound Servo (EZB) — Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion. Try it →
A Line Of Code Equivalent To Servo Release?
Hi,
after the servo moves, sometimes, i get a constant buzz from the servo, like the motor is still trying to lock and stay in 1 place. the servo already moved to the desire position. But to get rid of the buzz sound, i press "Release" button on the ARC Seervo control box. This stops the buzzing sound from the servo.
Is there a scripting command that is equivalent to "release" servo?
Spain
It's a good question, I'd like to know if that option exists, I have the same noise in the servos, and a script command to the robot would make more noise at the end of a sequence of movements, also reduce the consumption (less milliamps) servo.:D
Norway
_ezb.Servo.ReleaseServo(Servo.ServoPortEnum.SERVOPORT);
c# though :)
Does setting the servo to position 0 do it?
DJ, We can't find out because you give us the option from 1 to 36 only. Try to put a 0 in and it comes back wiith "must be between 1 and 36. A release command is really needed.
Sure is!:) I'm on it
Okay. Version 2011.10.24.00 has it. Enjoy
