Wowwee MIP V2 icon Wowwee MIP V2 — UART interface to hack WowWee MIP with ESP32/ESP32‑Cam or EZ‑B v4 for ARC; hardware UART preferred, configurable power and baud 9600/115200 Try it →
bing speech controlled by a script
Bing Speech Controlled By A Script
@TMesserschmidt
I tried the script from the tutorial "Add New AIML Categories with Voice." I encountered no errors, but the file created is always empty. To troubleshoot, I wrote a small script:
saywait("start script")
sleep(500)
controlCommand("Bing Speech Recognition", "StartListening")
sleep(4000)
controlCommand("Bing Speech Recognition", "StopListening")
sleep(1000)
print($BingSpeech)
saywait("script end")
This script runs without errors, but the Bing Speech Recognition does not seem to "listen," as the variable $BingSpeech is always empty. When I use the Bing Speech Recognition skill manually, it works perfectly with both "Start Recording" and VAD (Voice Activity Detection). It appears that the "StartListening" command in the script does not communicate with the "Bing Speech Recognition" skill.
I have the same issue with the original script from the tutorial. I have redone the tutorial twice, but the problem persists. Could you please check what might be causing this issue?
Azure Cognitive Speech recognition for ARC with custom API credentials, scripting, language control, and text output for detected phrases
Voice command phrase recognition that triggers scripts via your project’s speech-to-text engine, with confidence filtering and wake-word support.
It sounds like you're encountering an issue where the StartListening command in your script isn't properly triggering the Bing Speech Recognition skill. Let's go through a few steps to troubleshoot and ensure everything is set up correctly.
Step-by-Step Troubleshooting
  1. Check ControlCommand Syntax: Ensure that the ControlCommand syntax is correct. The command should be:
    ControlCommand("Bing Speech Recognition", "StartListening");
  2. Verify Skill Names: Make sure the name of the Bing Speech Recognition skill in your project matches exactly with what you are using in the ControlCommand. The name is case-sensitive.
  3. Check for Paused State: Ensure that the Bing Speech Recognition skill is not paused. You can unpause it using:
    ControlCommand("Bing Speech Recognition", "UnpauseListening");
  4. Test with Simple Script: Create a simple script to test if the StartListening command works:
    sleep(5000); // Wait for 5 seconds to allow speech input
    ControlCommand("Bing Speech Recognition", "StopListening");
    print(getVar("$BingSpeech"));
  5. Check Microphone Input: Ensure that your microphone is correctly set up and is the default input device. You can check this in the Windows sound settings.
  6. Review Bing Speech Recognition Settings:
    • Ensure that "Auto Record Using VAD" is unchecked if you are manually starting and stopping the listening.
    • Verify that the language and other settings are correctly configured.
Example Script
Here is a refined version of your script with some additional checks:
// Unpause the Bing Speech Recognition if it is paused
// Start listening
sleep(4000); // Wait for 4 seconds to allow speech input
// Stop listening
sleep(1000); // Wait for 1 second to ensure processing
// Print the recognized speech
var recognizedSpeech = getVar("$BingSpeech");
print(recognizedSpeech);
// Provide feedback
Audio.say("Script end");
Additional Debugging
  • Log Output: Add more print() statements to log the progress of your script and ensure each step is executed.
  • Skill Logs: Check the logs of the Bing Speech Recognition skill for any errors or warnings.
Resources
If the issue persists after these steps, please provide more details about any error messages or unexpected behavior you observe. This will help in diagnosing the problem further.
Germany
@athena, same problem. the variable $bingSpeech is always empty. here is a picture of the output of the script. If i use the skill bing speech recognition  and i start recording, he will display what i am saying, it is ok. If i use the script, he will display the word I have said in the skill bing speech recognition. The start listening command does not trigger the skill bing speech or the command is not understood by the skill bing speech
Thank you for providing more details. It seems like the StartListening command is not triggering the Bing Speech Recognition skill as expected. Let's try a few more steps to diagnose and resolve the issue.
  1. Ensure Skill Name Accuracy:
    • Double-check the exact name of the Bing Speech Recognition skill in your project. The name must match exactly in the ControlCommand.
  2. Check for Paused State:
    • Ensure that the Bing Speech Recognition skill is not paused. You can unpause it using:
  3. Test with Simple Script:
    • Create a simple script to test if the StartListening command works:
  4. Check Microphone Input:
    • Ensure that your microphone is correctly set up and is the default input device. You can check this in the Windows sound settings.
  5. Review Bing Speech Recognition Settings:
Example Script with Debugging
Here is a refined version of your script with additional debugging steps:
// Start listening
print("Starting to listen...");
// Stop listening
print("Stopping listening...");
print("Recognized Speech: " + recognizedSpeech);
// Provide feedback
Additional Debugging Steps
  • Log Output:
    • Add more print() statements to log the progress of your script and ensure each step is executed.
  • Skill Logs:
    • Check the logs of the Bing Speech Recognition skill for any errors or warnings.
Resources
If the Issue Persists
If the issue persists after these steps, please provide more details about any error messages or unexpected behavior you observe. Additionally, you can try the following:
  1. Reinstall the Skill:
    • Remove the Bing Speech Recognition skill from your project and add it again.
  2. Update ARC:
    • Ensure you are using the latest version of ARC. Sometimes updates include bug fixes that might resolve your issue.
  3. Contact Support:
    • If none of the above steps work, consider reaching out to Synthiam support for further assistance.
Please let me know if you need any more help!
Germany
@synthiam.support it still doesnot work with the script. I restarted ac,pc and i loaded a minimal configuration to start with a good basis. 2 skills are loaded, aimlbot and bing speech recognition. it works fine. i can talk to bing and i got a response. below is the config of bing, aimlbot has no script.  i made a script with the infos povided by athena but can not get it worked. the variable $BingSpeech is empty.. If I use the bing speech recognition by doing start recording or using VAD  this variable is set. heres the script provided from athena.
// Unpause the Bing Speech Recognition if it is paused ControlCommand("Bing Speech Recognition", "UnpauseListening");
// Start listening print("Starting to listen..."); ControlCommand("Bing Speech Recognition", "StartListening"); sleep(4000); // Wait for 4 seconds to allow speech input
// Stop listening print("Stopping listening..."); ControlCommand("Bing Speech Recognition", "StopListening"); sleep(1000); // Wait for 1 second to ensure processing
// Print the recognized speech var recognizedSpeech = getVar("$BingSpeech"); print("Recognized Speech: " + recognizedSpeech);
// Provide feedback Audio.say("Script end");
setting of skill big speech recognition
#5   — Edited
You’re using different variables for different stuff. In your screenshot the variables are different. And it’s using SetPhrase and such - and ControlCommand for start listening doesn’t wait.
im not fully sure what it is you’re trying to do. Can you explain it? That’ll help
@athena explain how the ControlCommand doesn’t wait and results of a async command such as startlistening should have code in the all recognized script of Bing. It’s documented in the manual as well.
but we can move forward if you can explain what your outcome is. Because I can’t quite make it out by the code or questions to Athena at this time.
Thank you for the additional context and for pointing out the asynchronous nature of the ControlCommand().Lets clarify how to handle asynchronous commands and ensure that the recognized speech is processed correctly.
Understanding Asynchronous Commands
The ControlCommand() for StartListening does not wait for the speech recognition to complete. Instead, it triggers the listening process, and the result is handled asynchronously. This means that the script will continue executing without waiting for the speech recognition to finish.
Handling Asynchronous Speech Recognition
To handle the recognized speech, you should use the "All Recognized" script within the Bing Speech Recognition skill. This script will be executed when the speech recognition process completes and the speech is recognized.
Steps to Implement
  1. Configure the "All Recognized" Script:
    • Open the Bing Speech Recognition skill.
    • Go to the configuration settings.
    • Find the "All Recognized" script section.
    • Add the script that processes the recognized speech.
  2. Example "All Recognized" Script:
    // This script will be executed when speech is recognized
    Audio.say("You said: " + recognizedSpeech);
  3. Triggering Speech Recognition:
    • Use a separate script to start and stop the listening process.
    • The recognized speech will be handled by the "All Recognized" script.
Example Script to Trigger Listening
// Start listening
print("Starting to listen.");
// Wait for a few seconds to allow speech input
sleep(4000);
// Stop listening
print("Stopping listening.");
// The recognized speech will be handled by the 'All Recognized' script
Summary
  • The ControlCommand("StartListening") does not wait for the speech recognition to complete.
  • Use the "All Recognized" script within the Bing Speech Recognition skill to handle the recognized speech.
  • Trigger the listening process using a separate script, and let the "All Recognized" script process the result.
Additional Resources
Please let me know if you need further assistance or if you have any specific requirements for your project!
@athena, you don’t have to send the stoplistening command because the listening will expire after it receives silence or times out. So you only need to trigger the start listening, and the response is processed in the All Recognized script
Thank you for the clarification, DJ Sures. Let's simplify the process based on your input.
Simplified Approach
  1. Configure the All Recognized Script:
    • Find the All Recognized script section.
  2. Example All Recognized Script:
    • Use a separate script to start the listening process.
    • The recognized speech will be handled by the All Recognized script.
// Start listening
// No need to send StopListening; it will automatically stop after receiving silence or timing out
Summary
  • Trigger the listening process using the StartListening command.
  • Handle the recognized speech in the All Recognized script.
  • No need to send the StopListening command; it will automatically stop after receiving silence or timing out.
