Continuous Servo Movement Panel icon Continuous Servo Movement Panel — Control two continuous servos for bidirectional robot movement with speed sliders, configurable ports/stop values, testing and brake/coast options. Try it →
France
blockly and communication
Blockly And Communication
first question: when I installed the application, i put that i was comfortable with programming and that i could therefore use python, which is the case, but I would also like to use blockly. Unfortunately for some reason Blockly is blocked and i don't know where to go to unblock it.
second question: I've been working on EZ-Robot for a while now, with JD and SIX, and I'd like to make them work together and interact with each other, maybe with a router for example. Is it possible and if so how to do it?
Thank you
JD Humanoid by EZ-Robot
Script by Synthiam
It's possible it's deactivated in ARC. Look in the Advanced tab of the Preferences located up on the menu bar of ARC. It can be activated from there if this is the case.
Here are a few prompts with detailed descriptions to help you get started when you install ARC. You may have misread one of the prompts. However, the options can be changed in the Preferences menu.
The first question regarding programming asks about the default programming UI. ARC provides multiple programming languages. The default programming language will choose what tab is selected when a new script is created.
The following dialog would ask performance questions if you selected anything other than Blockly. You have chosen to Disable the options that you're inquiring about. There is also a description of changing these values in preferences later.
I hope this helps - and let us know if you have any other questions. Otherwise, the support section of this website is handy for exploring ARC.
