Hi
I have a JD humanoid robot
fully charged - flashing green on back
when I turn it on it say something like go to the website and the connected to my network
I locate the ip, click on it, then it says "not an EZB"
what is this
Sound Servo (EZB)
— Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion.
Hi
what is this
can you connect in ARC and use this button?.
Hello @EZang60,
I wanted to double check if you needed to use client mode or if AP mode would suffice.
AP mode is the default mode and is much easier to connect your robot. I would recommend using AP mode with your JD before you tackle client mode.
Just use a paperclip to press the reset button on the upper left corner of the EZ-B and begin from defaults.
If you would like to continue with client mode, please see @Nomad's post above and the following tutorial
got robot working
now when I syn: I ge:
Downloading all EZ-Bit list... 56 EZ-Bits indexed Comparing against your library... Download 6 EZ-Bits... (This may take a while)1 of 6) Downloading Humanoid Body v0.1 by EZ Robot (5,599,954 Bytes) Error downloading from EZ-Cloud: Could not find file 'C:\Users\Public\Documents\EZ-Builder\EZ-Bits v2\1\a0349118-0d26-449d-a29b-45a1656a9231.ez-bit'
hi EZang here some pics where to find the file.or chould be.Thanks for all the help
next issue :-)
I can't save or save as any project, is something wrong with the program?
Ang
@EZang60... The "program" isn't the issue.... You just need to learn how to use it (and maybe even Windows) and you will be fine...
EZang60
first thing first,do you have the file ?the first time you ( save as ),averthing after that just use save.
here it what it says
AlsoVersion: 2019.03.17.00System.IO.FileNotFoundException: Could not find file 'C:\Users\Angelo\Documents\EZ-Builder\ProjectHistory.txt'. File name: 'C:\Users\Angelo\Documents\EZ-Builder\ProjectHistory.txt' at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding) at System.IO.File.WriteAllLines(String path, String[] contents) at JA0xRDwbQZ5O2TRBvr.vnJoGOW2dDfU2ebLil.mhoDxn7EBS(String ) at EZ_Builder.FormMain.YbVkImcSxR(Object , EventArgs ) at System.EventHandler.Invoke(Object sender, EventArgs e) at System.Windows.Forms.RibbonItem.OnClick(EventArgs e) at System.Windows.Forms.RibbonButton.OnClick(EventArgs e) at System.Windows.Forms.RibbonMouseSensor.Control_MouseClick(Object sender, MouseEventArgs e) at System.Windows.Forms.Control.OnMouseClick(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Ribbon.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
