Sound Servo (EZB) icon Sound Servo (EZB) — Map EZ-B audio volume to servos; multi-servo mirroring, scalar range control, invert/min-max, waveform feedback to sync mouth motion. Try it →
New Zealand
Custom Hexapod Build
Can I use the EZ-B v4 and the ARC to make my own custom Hexapod with leg lengths that differ from the EZ-Robot six hexapod kit ?. Will the ARC be able to calculate inverse kinematics for my custom hexapod ?
EZ-B V4 Info by Synthiam
Displays EZ-B v4 internal temperature and battery voltage, shows built-in battery monitor and LiPo protection settings in Connection Control.
#1   — Edited
You bet! That’s all the easy stuff for ARC:D. Explore ARC on this website and use the getting started guide to, well, get started. Also look into the Auto Position skill control.
For reverse kinematics, the servos you choose will have to support bidirectional positioning. This is all documented in the Auto Position skill control
