Sound Movement icon Sound Movement — Stereo mic sound localization triggers left/right scripts to control robot movement, enabling directional responses (turn/move) to audio. Try it →
division Of Labor Between Ebz Controller And Pc When Slowly Moving Servos
Division Of Labor Between Ebz Controller And Pc When Slowly Moving Servos
Assume I do a slow servo move from 0 to 100 which takes a few seconds. How does this work "behind the scenes" ? Am I right that the PC will sequentially send each individual position over wifi, and spread their timing to achieve the desired speed, rather than offload the entire instruction sequence to the EZB to be executed locally? If so, is there any feedback from the ezb controller to the PC to acknowledge it received the last command and does the PC wait before sending a new one? Or is the pc just sending each position on the assumption it will be received for as long as the board is connected?
Reason Im asking: Im seeing some occasional violent jerking where the head of my inmoov moves at full speed, despite all my attempts to limit the speed. My theory is that this is due to the EZB being busy or the wifi being unresponsive/briefly encountering a high latency spike for a short while, and the EZB software just keeps sending its sequential positions assuming they are executed, but when they are not for like half a second or so, this results in a full speed movement to "catch up".
If my assumption is correct, is there anything I can do about this? Like offload the entire slow movement sequence to the ezb so it can execute it autonomously without help and without persistently low latency connection to the PC?
Also, still based on the same assumption, stepper motors would be out of the question without a separate microcontroller?
I actually could not do that with an arduino, not in combination with an eink display at least. The display driver couldnt be run asynchronous or be interrupted, and each refresh took long enough that I would lose steps. So I had to use multithreading on a dual core esp32 for that... yes, 2 arduinos would have worked too, and I even did that initially but thats rather a pita to manage.
Similarly adding arduinos to a ezb project may be cheap, it also means more cable clutter, two different code bases, two different languages, two different IDEs, USB connections every time you need to modify the code... if all you want to do is control a single stepper, that all seems unnecessarily complicated and puts stepper motors out of reach of many/most? ezb users.
Of course, thats your call, but given the abundance of cheap stepper motors and the cool things you can do with them, Id call that a missed opportunity.
