Pandorabots icon Pandorabots — Connects ARC to Pandorabots for AI chat, sends text and gets replies (executes [EZ-Script]), integrates with speech recognition and custom bots Try it →
dynamixel trouble?
Dynamixel Trouble?
Hello,
I've just updated to ARC software. I am getting an error on startup regarding the dynamixels in my project. Is this plug-in working with the new ARC software? I looked and can not find any updates for the dynamixel plug in? Thanks      Chris
#2   — Edited
Update all the plugins you have installed. When the software loads, it’ll prompt for you to update if there’s an internet connection.
Hi, yes it does say update the plug in. However when I try to do that it says it can’t because there is already a instance or object of it already in arc. It said to shut down ARC and re- try. I tried that and a computer re- boot. Hopefully I’ll get done more time with it tomorrow but I hope I don’t have to delete the plug in that’s already there and set up.
The configuration is saved in the project file.
You don’t have to delete the plugin.
Follow the update instructions and it’ll all be good. Don’t try to update when the plugin has already been loaded. Do the update before it’s been loaded. And you can’t have another copy of ARC running while update. The plugin cannot be in use while updating. I pretty much just repeated the update instruction that you have read:)
So Im really not trying to be a pain in the axx. but I've downloaded the updated dynamixel plug in directly to my desktop. Before even launching ARC I double click on the update and it still fails to install. Says there is already an instance of that plug in. I haven't even opened up ARC yet and it says that????
   Thanks again guys
                                              Chris
Can you copy and paste the error?
You bet - we'll get you running in no time:D
