ZAMA Emotion Model icon ZAMA Emotion Model — Valence-arousal emotion engine generating persistent, configurable robot moods and event-driven emotional outputs for expressive behaviors. Try it →
:Ermm:Hi My Name Is Bart From
:ermm:Hi my name is Bart from Belgium, brandnew to the community. I recently received an EZB and have a connection problem with the program ARC itself. Rest works fine.
JD starts Up, connects to the network, confirms it by saying so, My Ip scan confirms he's pretty well active @ 192.168.0.226 ; Green LED blinking on the back.
Now comes the weird part. JD is connected, when scanning for connection with ARC, JD Blips @ 192.168.0.226, LED on his back turns from blinking to contineous. But the scan doesn't register the IP and Ihave therefor no connection with JD. Even weirder is that JD's camera does operate through 192.168.0.226 Done several new installs, cleaned properly before reinstalling, I'm at the end of my wits here
Best of Holidays to evreyone, Merry Christmas and a happy new year
bart i left some comment on your skype.
8-)Other Opinions and any Idea as to solve this is still very welcome
Hey DJ,  Merry x-mas and than
And thanks for the reply. But I've been through every single step of them, a number of times even.
I can give you every single detail explained in these in Screenshots if you like. I don't understand why only the connection tab refuses to pin the working IP of JD. See Screenshot links a few posts earlier
#23
Reset the ezb as per my previous direction
Does it work when you connect directly to it in ap mode by following the tutorial?
I believe you’re skipping some steps in the learn section for the jd ezrobot product. Start with the default setting as a new user first. Verify it works that way.
Then you can connect it to your network and debug using the prompts and tutorials to ensure there’s no avg anti virus etc
I'll try and try again and will get him running don't worry ;-) really just can't See what I could have missed. Did the whole process from scratch together with Nomade_6R life through Skype so that I could follow-up on my screen. Communication is fine, gets connected, I can Run the full diagnostic directly from my Browser, in ARC, cam works, only does the tab connection not pin the IP.
