Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
error playing sound files
Error Playing Sound Files
hi
i downloaded the latest version ARC and now i cant play sound files ? also notest the window ezbv4 info is not showing ? also notest the Auto Position doesn work ?
when i choose the ezbv4 in the Auto Position .it doesn save it .
I think you need to check your code because there are no issues with playing audio. Perhaps you're attempting to play audio before a successful connection to an EZB that supports an audio codec.
hi dj
as you can see the ezb is connected in the picture above . it seems that ARC or Auto Position dont recognize my ezb . i use this one for many years . the previous version no problems . it started the last update .
Make sure your soundboard is on ezb index #0
Hmmmm - i'll have to take a look and see if I can reproduce it.
also the rgb seems to work in the window but not the rgb itself . the standard rgb lids up thats all .
i deleted all ARC and redowloaded .now its changed .it says connected.  still same errors .
could it be possible that there is no save button on the page where you choose your device ? ( unknow )
