Wavefront icon Wavefront — Wavefront grid planner computes collision-free, deterministic paths from start to goal using known occupancy maps for indoor robots. Try it →
Export A Skill From A Project To Another One
, is it possible to "export" a skill from one project to another in Synthiam ARC, similar to how we can do with the Auto Position skill? If not, is there an alternative method to achieve this?
For example, in one of my projects, I have the RGB Animator skill, which I originally imported from the JD robot. This skill includes many actions. However, when I start a new project, the RGB Animator skill appears empty. It would be beneficial if I could transfer the actions from the RGB Animator skill in the JD project to the new project.
I'm asking because I've experienced several instances where ARC becomes unresponsive, requiring me to wait for about 10 minutes before I have to close the window and restart everything. The most significant issue was with the Auto Position skill, but thanks to the import/export feature, recovery was easier. I initially suspected a problem with the camera because I once saw an I2C error message in the camera window. However, I later experienced a freeze even when no camera skill was installed.
Currently, I'm unsure of the cause, so I've decided to start a new project and install each skill one by one. If the problem persists, I plan to try using another PC with Windows 10, as I am currently working with Windows 11.
JD Humanoid by EZ-Robot
Germany
thanks for your help. ll keep working by adding skills.
I always thought of merge as a closely guarded secret, helped me out so many times!
