Sphero Movement Panel icon Sphero Movement Panel — Control Sphero via Bluetooth in ARC. Detects two COM ports (one connects); requires deleting and re-pairing after disconnects or reboots. Try it →
Japan
ez-arduino with L293
Ez-Arduino With L293
I used the L293 module connected to arduino, the ultrasonicsensor to make the rotbot automatically avoid obstructions, so when I turned the arduino into ez-b, I could connect it to L293, the ultrasonic sensor and do that project withez-cript similar to the code C++ II wrote and it doesn't seem to work?
USB
Servos 12
ADC 6
Digital 14
#1   — Edited
What tutorials did you follow that weren’t able to assist? You looked at the hbridge control manual? And the ultrasonic distance sensor manual? I don’t see either of those controls added as reference when this question was created.
I would start by following the tutorial on connecting an arduino to ARC. If you look at the synthiam's arduino uno hardware page in the getting started guide, there are specific step-by-step instructions.
Here's my recommendation
  1. Program the Arduino Uno with latest firmware to turn it into an EZ-B: https://synthiam.com/Hardware/Arduino-Genuino-Uno-17527
  2. Follow the steps on the above link to connect ARC to the Arduino Uno via USB
  3. Add the PWM HBridge Movement Panel to your ARC project and specify the ports in the config for your sheild: https://synthiam.com/Software/Manual/4-Wire-HBridge-PWM-16067
  4. Add any of the ultrasonic controls that best suits your requirement for navigation. Simple obstacle avoidance could be done with this: https://synthiam.com/Software/Manual/Ultrasonic-Radar-16101
Oh yes thanks , that's what I should review and will do it tomorrow
