Brazil
firmware IoTiny
Firmware Iotiny
My IoTiny has corrupted the Firmware and now it no longer works with just a blinking blue Led and does not recognize on the Wifi network. What can I do to recover the firmware?
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
How did you corrupt the firmware? Are you certain it's not damaged?
Please do no double post:) We can see your single post
Brazil
at the moment of the update of Firmware of my Io-Tiny lacked energy and my computer shut down in the middle of the update.
Hi,
I have the same issue: the firmware update failed in the middle of the process and now the blue led of the Io-Tiny blinks very fast... and that's all. So, if there is a way to solve that, I am really interested :-)
The only thing I can think of is pressing the reset button, and see what happens but if that doesn't work there's no easy way to recover from this situation.
You would have to directly reprogram the WiFi module firmware with an STLINK V2 programmer which is challenging as there isn't a programming header breakout. It would require soldering directly to the programming pins on the side of the WiFi module. I guess you could use some pogo pins to temporarily connect to the programming pins but it would be difficult to prevent them from shorting out on each other.
The connections you'd need to attach to the STLINK are:
Pin 25 SWD_SWCLK Pin 26 SWD_SWDIO 3.3V GND
In summary, yes, it is possible to reprogram the IoTiny's firmware but it is a challenge. The time and effort will cost you more than the cost of a replacement IoTiny.
#5   — Edited
The way to recover the firmware is to first check if the device is indeed operating. It’s very very very difficult to corrupt the firmware - and has never been achieved by me. I’m guessing you accidentally damaged the iotiny and hoping the firmware fixes it - it won’t. The firmware upload process doesn’t actually write the firmware until the very last second. There’s a very small window to corrupt a firmware upload.
To check if the chip is operational, you will require a usb to uart adapter. Check the data sheet and connect the rx and tx of the usb to tx and rx of the camera port. And of course shared ground.
Then, hold the reset button down on the iotiny and apply power to the iotiny.
That will boot the iotiny into the boot loader console. Use a terminal program to view the boot loader console.  You can verify the firmware and upload new firmware using commands. There’s a help dialog to provide help
this same process works with the ezb v4.x/2
Whoops! It must must have been too early on a Monday morning because @DJ's solution completely slipped my mind.xD
Hi DJ, I assure you I didnt' try to fix the IoTiny with a firmware update. My IoTiny was just fine before the update.
I have one EZB v4 & two IoTiny and try to make a firmware update for all of them. It goes well for the EZB and the first IoTiny, but for the second one, the update stops at the middle of the process, with an error message. After that, the blinking led...
I think I have an usb to uart adapter somewhere, so I will test your solution as soon as I find it.
By the way, as I use the lattepanda as a computer, can I connect it directly to the tx and rx of the camera port, instead of using the usb adapter?
Thanks for the help.
OK, So I successfully boot the iotiny into the boot loader console and access it through a terminal.
I entered the help and guessed that I have to use the FWUPDATE command, but i am stuck. I don't now how to send the firmware... I think it goes beyond my knowledge now, but I would be happy to learn.:)
