hello i have quetion about servos can i use 270 degree LD-3015MG with ez-b i am making robot my own an i like more movement than 180
WRBT
Finland
Neopixel Ring
— ARC UI for onboard computers to control NeoPixel rings via serial: test/run patterns, preview and copy Arduino serial commands, includes sample code.
Yeah - you sure can. Because they operate like generic standard servos, with the only difference is they move more degrees within the same signal. This means that 180 in ARC would be 270 on the servo.
