BV4615 RC-5 IR Decoder icon BV4615 RC-5 IR Decoder — Adds IR sensor support and button mapping for USB joysticks in ARC, enabling remote control functions; third-party hardware supported. Try it →
Resolved Resolved by Athena!
How To Modify The Bot Name In Aimlbot ?
I am experimenting with AIMLBot and would like to give the bot a personal name, such as John. When I ask, "What's your name?" it should respond with "John." I have checked some AIML files and the configuration file, but it is not clear what needs to be changed. By changing the name, my robot will feel more personalized. Could you please tell me which file I should modify? Thanks!
Aimlbot by Synthiam
Localized AIML chatbot with editable AIML files, ez-script support, session memory and ControlCommand API; integrates with speech and robot skills.
Bot Libre by Bot Libre
AIML2 chatbot client for ARC connecting robots to Bot Libre cloud for customizable, private chatbots and personalities.
Pandorabot AIML2 by Synthiam
Connect ARC to Pandorabots AIML2 to run AI-driven virtual personalities for human-like text or voice chat, using API keys and script hooks.
You could ask the AIML what its name is. Then search the files using the editor for that name.
There’s info on the aimlbot manual page about how to search using the editor. That way you can find any references that you want to change.
To personalize your AIMLBot and give it a name like "John," you'll need to modify the AIML files where the bot's name is defined. Here's a step-by-step guide to help you achieve this:
Step 1: Open the AIML Configuration Folder
  1. Open ARC and load your project.
  2. Select the AimlBot skill from your project.
  3. Click on the gear icon to open the configuration settings for AimlBot.
  4. Click on "Open Config Folder" to navigate to the folder containing the AIML files.
Step 2: Search for the Bot's Name
  1. In the configuration settings, click on "Search".
  2. Enter the current name of the bot (e.g., "Bot") in the search field and press "SEARCH".
  3. This will display all the AIML files and lines where the bot's name is mentioned.
Step 3: Modify the AIML Files
  1. Open the AIML files that were found in the search results using a text editor or the built-in GaitoBotEditor.
  2. Look for the <category> tags that define the bot's name. It might look something like this:
    <category>
        <pattern>WHAT IS YOUR NAME</pattern>
        <template>My name is Bot.</template>
    </category>
  3. Change the response to your desired name, "John":
    <category>
        <template>My name is John.</template>
    </category>
Step 4: Save and Reload
  1. Save the modified AIML files.
  2. Reload the AimlBot skill in ARC to apply the changes.
Example
Here is an example of how you might change the bot's name in an AIML file:
Before:
<category>
</category>
After:
<category>
</category>
Step 5: Test the Changes
  1. In ARC, type "What is your name?" in the AimlBot text entry field.
  2. The bot should now respond with "My name is John."
Additional Customization
You can also set the bot's name programmatically using the SetValue ControlCommand. For example:
ControlCommand("AimlBot", "SetValue", "name", "John");
This command can be used in scripts or other robot skills to dynamically change the bot's name during runtime.
By following these steps, you can personalize your AIMLBot to respond with the name "John" or any other name you prefer. If you have any further questions or need additional assistance, feel free to ask!
Germany
@athena, the bot has answered that his name is alice . ok i modified 2 files ( alice and y) in the config folder aiml and it looks better. It is not perfect since sometimes, depending on the question, it can answer, my name is unknown or if i ask " is your name john", it says yes!. so i think the process fetches some infos in several files and i dont get always the same answer. lets say the issue is closed, i will add a camera detect face as DJ has made in a video, can be interesting to see the interactions
Germany
@EzAng . finally i could modify it, in the folder config the file settings. i could see the bot name,imodified as well genre, location...thanks
