Resolved Resolved by Athena!
how to set 3 servo's
How To Set 3 Servo's
I have constructed a neck mechanism for the PIB robot and would like to control all three servos using a single Movement Panel in Synthiam ARC. Could you guide me on how to configure the settings for this setup? Each leg of the neck mechanism has a servo attached, and the goal is to enable the head to move in all directions.
Here are the images of my setup for reference:
Create servo frames/actions to animate humanoid, hexapod or custom gaits with smooth transitions, SW ramping and directional control
#18
I agree with @DarkHarvest. It looks like the vertical servo has a dirty potentiometer or something that causes it to vibrate at one position. When the head gets into the position, the servo seems to vibrate. Do you have another servo to swap with it and see if that resolves it?
@dj@darkharvest
i need to make it stronger . these are just test . i have another servo . great advise .
