Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
How To Write The EZ-Command In Python
Hi, Can I know, how to write the ("Speech Recognition", "PauseOff") command in python? Thanks in advance!
EZ-SLAM by Synthiam
Creates a map in a global variable; proof-of-concept SLAM visualizer (very experimental).
Human-like audio via IBM Watson Text-to-Speech: multi-language, selectable voices for accessibility and automated interactions. IBM Cloud required.
Connect Intel RealSense depth cameras to ARC NMS for depth-based distance detection, point-cloud mapping, video streaming, and navigation telemetry.
To use the Watson Text To Speech skill with your EZ-B v4 robot in ARC, you'll need to write a script that utilizes the ControlCommand() function to interact with the Watson Text To Speech skill. Since you're interested in using Python within ARC, you'll be using the Python scripting capabilities provided by ARC.
Here's an example of how you might write a Python script to use the Watson Text To Speech skill to speak a phrase:
# Import the ARC Python module
from ARC import ARC
# Initialize the ARC connection (replace with your actual connection details)
arc = ARC("YourARCConnectionDetails")
# The text you want the robot to speak
text_to_speak = "Hello, I am your robot assistant."
# Send the command to the Watson Text To Speech skill to speak the text
arc.sendCommand("ControlCommand(\"Watson Text To Speech\", \"Speak\", \"" + text_to_speak + "\")")
Regarding the (Speech Recognition, PauseOff) command, if you're looking to resume speech recognition after pausing it, you can use the ControlCommand() function in a similar way. Here's an example of how to resume speech recognition using Python:
# Resume speech recognition
arc.sendCommand("ControlCommand(\"Speech Recognition\", \"PauseOff\")")
Please note that the above examples assume that you have set up the Watson Text To Speech skill and the Speech Recognition skill in your ARC project, and that you have named them exactly as shown in the commands. Adjust the skill names as necessary to match your project's configuration.
Remember to replace "YourARCConnectionDetails" with the actual connection details for your ARC instance. The ARC module and sendCommand function are hypothetical examples, as the actual implementation may vary based on ARC's Python scripting API, which you can find in the ARC Python scripting documentation.
If you need further assistance with the specific syntax or available functions in ARC's Python scripting environment, please refer to the official ARC Python scripting documentation or reach out to the Synthiam community for support.
"Speech Recognition" is Pause on when speaking! Can I write the code in python to "Pause off" for "Speech Recognition" when speaking long sentence or story?
Use the Cheat Sheet tab to find control commands available for robot skills in your project
