Resolved Resolved by Athena!
howmany voltage regulator is needed
Howmany Voltage Regulator Is Needed
do i need a voltage regulator per servo ? or one voltage regulator per complete robot set up ?
#83
Quote:
would this work in ARC ? servo travel tuner .
I don't know. these are a mystery to me.
@dave
another thing for testing then . i ordered a few .
hi:D
wel starting to learn some krimping . looks like a pro . use the right tool . its an automatic stripper . it strips even the smallest wire .
tools
video soon first part of the build inmoove chair .
hi:)
i install the convertor on a bridge . to lift it off the board . on the botem are some open holes . with the bridge some heat can pass now . and the tube for power wires come thru . there are just two tiny holes for a screw to holt the convertor in place . so i printed some parts , to keep the convertor in place .
some pictures .
