Google Speech Recognition icon Google Speech Recognition — Google Speech for ARC: cloud speech recognition with waveform, configurable response scripts and PandoraBot support Try it →
Resolved Resolved by Athena!
howmany voltage regulator is needed
Howmany Voltage Regulator Is Needed
do i need a voltage regulator per servo ? or one voltage regulator per complete robot set up ?
Twitter
#121
Nothing worse than 1am in the morning everyone is asleep.  You are being super quiet and just tweaking the last settings in your script and all of a sudden a loud shriek from your EZB,
MY BATTERY IS LOW, MY BATTERY IS LOW, MY BATTERY IS LOW.
@dave @nink
yeach am almost there . just the small regulators for each controller set at 6 volts . in ARC batterie settings put them on 6 volts insteadt at 7 volts .
some test print
the copper color is very ruf . i think am gonna re print in black . i overpainted the copper  whit black .:( not so nice .
#123
I'm curious, in a different post you mentioned you were not using batteries anymore and wanted to disable the low battery warning. If you're using AC wall current and not batteries what's your reasoning behind keeping the voltage monitor for the EZB's active? Again, I'm just wondering.
I'm impressed with your skills you're using in this build. Nice work so far. I'm looking forward to seeing more.
hi:p
the iotiny is off bateries now . all on wall socket power . this configuration with step down regulators and back up with the small ones . needs to be 6.50 volts for power the iotiny . els it would no have enought voltage , for excample to lid up two eyes as seen in  the video . i raised the volt from 6. volt to 6.5 volts . i also included the ARC name of this project as NO BATTERIES PROJECT.
https://www.youtube.com/watch?v=V26IdmnPHOU
hi all
big progress . all regulators are in place .and all works . lots of playing with RGB and led's:p if you dont have room to place all next eachtother ..then place it ontop .
regulators ontop 6.50 volts each .
how the backside looks .
a little video .
https://www.youtube.com/shorts/Q4yq3vh9y34
@dave
if my understanding of power to the controllers is correct , it doesn matter if the volt to the controller is 7.4 volts, or 6 volts for the servo's cause they will get there volts from the terminals ?so that means all controllers can have 7.4 volts ? question , is my assumption correct on this ?
thanks
