Wheel Encoder Counter icon Wheel Encoder Counter — Arduino UNO wheel encoder: reads left/right ticks, provides counts, configurable ticks, wheel & pivot sizes, optional pose telemetry to ARC NMS. Try it →
Resolved Resolved by Athena!
howmany voltage regulator is needed
Howmany Voltage Regulator Is Needed
do i need a voltage regulator per servo ? or one voltage regulator per complete robot set up ?
#41   — Edited
I don't think I understand your question. But, the three lugs you are pointing to are the three positive 5 volt DC outputs. DO NOT connect the AC input power there. AC power connects to the left side of the converter.
Each of your 5 volt output circuits  (on the left side of the converter) will have one 5v positive (+V) wire and one Com (-) wire.
ah so only one v+ and one v- will be used to connec to terminals ? and averything els wil be connected to the terminals servo's/lights ?
V- IS NEGATIF ? v+ IS POSITIF ? so there are 3 V- AND 3 V+ ?  3 channels .
#43   — Edited
Based on the link that DJ posted I thought you had three 5 volt dc positive lugs  and three com lugs  I took a closer look at the picture you posted and your's only has 2 each. I don't know why there is a difference if you got what DJ links to. Would you mind posting the link you bought your converter from? I would like to take a closer look at it. It could be as simple as what's available to me here in the United States opposed to you from your country. Also could you take a picture of the nameplate mounted on the converter that has all the specifications on it and post that also?
#46
Hey dude - the gnd and +5v are labeled here. There are 2 connections for each, but they're the same and shared.
Your mains power input is here...
And you can adjust (fine-tune) the 5v output with the dial here
OK, thanks for the pictures. You have the converter you expected with the exception of only two DC outputs (V+ and Com). Now I know what you have for sure.
I'm going to sit down a little later on and try to draw out a simple schematic of where to attach your wires. Seems that writing about it has its challenges. No worries.
hi dj/dave
thanks you for the pictures . so V- is negative v+ is positive .
