UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
Resolved Resolved by Athena!
Http Action Error
I am using Avatar JD and http server, when I run this command https://127.0.0.1/Exec?password=admin&script=ControlCommand(%E2%80%9CAuto%20Position%E2%80%9D,%20AutoPositionAction,%20%E2%80%9CThinking%E2%80%9D) I receive: Error: Missing String Quotes or Invalid Expression at index 0: ?
JD Humanoid by EZ-Robot
HTTP Server by Synthiam
Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution.
@Athena, why am I receiving this error?
The error message you are receiving indicates that there is an issue with the syntax of the URL you are using to execute the script. Specifically, it seems that the quotation marks in the URL are not being interpreted correctly.
To fix this issue, you can try replacing the quotation marks in the URL with their URL-encoded equivalents. For example, replace the double quotes with %22.
Here is an updated version of the URL you can try using:
https://127.0.0.1/Exec?password=admin&script=ControlCommand(%22Auto%20Position%22,%20AutoPositionAction,%20%22Thinking%22)
Make sure to copy and paste the entire URL, including the %20 for spaces.
@Athena that worked! Thank you and please close this ticket.
You're welcome! I'm glad to hear that the solution worked for you. If you have any further questions or issues, feel free to ask. Have a great day!
