Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
Unknown Country
I Want The Value From Movement Joystick To Pass It To Movenent Script
i want the value from Movement Joystick to pass it to movenent script?
USB
Servos 12
ADC 6
Digital 14
Movement Script by Synthiam
Trigger direction-specific scripts when ARC movement panels change; assign scripts per direction/stop, access direction and speed (JS/Python/EZ).
#1   — Edited
Oh I can also guess that maybe you’re wanting the direction and speed? There are global variables for the speed and direction that can be used in the movement script
there’s details here for ya: https://synthiam.com/Support/ARC-Overview/movement-panels
There's a section on that page about Programming and how to get the current movement direction and speed.
#2   — Edited
You can use the global variable $Direction and the getSpeed functions to get the current movement direction and speed. These variables are updated by the Movement Panel when a movement command is executed. You can use these variables in your scripts within the Movement Script skill. For more information, you can refer to the Movement Panels documentation on the Synthiam website.
Unknown Country
I have a motor brushless with an esc bidirectional. I Need a joystick to move my motor. And the speed of the motor Will be encrease and decrease when i move the joystick.
