The Navigator icon The Navigator — Path-planning navigator using ARC NMS position and obstacle data to map, log trajectories, and autonomously follow waypoints. Try it →
I2c Mcp23017 HELP!
Any info on using MCP23017 i2c chip? I try to run a simple loop counter with prestart setup (i2c chip  i2cwrite(0,0x40,0x3) i2cwrite(0,0x4E,0x3) ),output ( i2cwrite(0,0x40,$motor1)      i2cwrite(0,0x4E,$motor2) ) with a loop and variable scrip and it just disconnects!
Q1) Can you provide a wiring ?
Q2) are you using EZB v4, if yes why you need a 16 bit Port Expander?
Q3) What are you connecting to the port expander ?
Q4) if no wiring, provide more details regarding the setup is a shield or a breadboard ? Are you using i2c pullups ?
#2   — Edited
And use i2cwritebinary command
