Feetech Serial Bus Servo icon Feetech Serial Bus Servo — Control Feetech SC serial bus smart servos via EZB UART or PC COM port with ARC virtual ports, speed, position, release, and acceleration. Try it →
#1   — Edited
Yes. Push the EZ-Script tab and view the generated code and editable in EZ-Script. Remember that it's one way. You can't generate Blockly from ez-script.
Thank You, that was easy.     I had started on the script with Blockly using the f9 on the File overview page. which only has a code tab that does not let you edit.
you guys are the best!!
