let me ask: can ez-b be used for all types of servo? sorry i just got acquainted with ez-b!
tu2002
UBTECH Alpha Servos UBT-12HC
— Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping.
EZ-B v4 works with standard PWM servos, dynamixel, ubtech and lewansoul servos. Chances are, it works with the servos you are thinking of. Post picture or links to your servos. However, there's a lot of cheaply made servos so we recommend EZ-Robot HDD servos or Dynamixel servos only.
Actually that is good info just before I go on a mad servo buying spree!
let me ask: can ez-b be used with this type of servo?Please do not double post. Re-use the same post on the same topic. I moved your post into this thread since it's the same topic. Keep things organized, please. It helps to keep posts organized for new users in the future.
Yes, the EZ-B v4 or IoTiny will work with both of those servos. however, be warned that those servos are incredibly low quality and will most likely burn out within the first month of use. We recommend Dynamixel or EZ-Robot HDD servos.
