EDU Activity Editor icon EDU Activity Editor — Design, edit and export structured Blockly-based lessons, groups and hints for ARC Lite Portable; supports rich HTML, images, JSON import/export. Try it →
Resolved Resolved by Athena!
movement panel for stepper motors
Movement Panel For Stepper Motors
Can you please write the code in Blockly for me for a stepper motor Movement Panel using V21 and V22? I will be inserting it into Auto Position movement panel.
Stepper Servo by Synthian Inc.
Control up to 127 stepper motors via Arduinos mapped to ARC servos; supports any stepper driver, serial network, home calibration, speed/accel.
#17
Haha that’s usually how it happens:)
How did you end up doing it?
There’s probably a way to offload the loop to the ardunio with an option to "set as continuous rotation servo" but I’d have to figure that out. I think Athena’s past suggestion of a JavaScript loop in a custom Movement Panel v2 is the easiest so far.
#18
I already had stepper movements with keys and with joystick buttons, just had to have Movement Panel give me something, that something is either joystick variable value or a direction. Cheers!!
