Wavefront icon Wavefront — Wavefront grid planner computes collision-free, deterministic paths from start to goal using known occupancy maps for indoor robots. Try it →
movement panel with servo control
Movement Panel With Servo Control
I have modified my 3-wheel robot by replacing the two 360-degree servos with a motor equipped with a differential. This motor is controlled by a dual H-bridge using PWM signals. While I'm not entirely sure if this is the optimal setup, I'm still learning and experimenting with various possibilities. Currently, the single motor controls both rear wheels, allowing for synchronized forward and reverse movement, which is functioning well.
For steering, I have installed a servo at the front to control the wheel's left-right movement. However, I'm encountering an issue where the joystick correctly manages the forward and reverse motion but fails to control the steering. I would like to have a single control interface or "tool" that can manage both forward/reverse and left/right steering using the servo. If achieving this with a joystick is not feasible, could you suggest an alternative solution?
Adventurebot by EZ-Robot
AdventureBot with Synthiam ARCx: drive, stream live video, follow faces and colors, use speech, AI, and browser control.
Custom Movement Panel maps directional commands to scripts, adjusts per-wheel speed (0-255), and integrates with joysticks for unsupported motors
To achieve a single control interface that manages both forward/reverse movement and left/right steering using a servo, you can use the Custom Movement Panel in ARC. This setup will allow you to control the differential motor for forward and reverse movement and the servo for steering. Here's how you can configure it:
Step-by-Step Configuration
  1. Add the Custom Movement Panel:
    • Open your ARC project.
    • Go to the Project tab and click on Add Skill.
    • Navigate to Movement Panels and select Custom Movement Panel.
  2. Configure the Custom Movement Panel:
    • Click on the gear icon to open the settings for the Custom Movement Panel.
    • In the settings, you will find script sections for each direction (Forward, Reverse, Left, Right, and Stop).
  3. Script for Forward and Reverse:
    • Use the PWM commands to control the H-bridge for the motor. For example:
      // Forward
      PWM.set(D0, 100); // Set PWM for forward motion
      PWM.set(D1, 0);   // Ensure reverse is off
      // Reverse
      PWM.set(D0, 0);   // Ensure forward is off
      PWM.set(D1, 100); // Set PWM for reverse motion
  4. Script for Left and Right Steering:
    • Use the servo commands to control the steering servo. For example:
      // Left
      Servo.setPosition(D2, 60); // Adjust the position for left steering
      // Right
      Servo.setPosition(D2, 120); // Adjust the position for right steering
  5. Stop Script:
    • Ensure both the motor and servo are stopped or set to neutral when the stop command is issued:
      // Stop
      PWM.set(D0, 0);
      PWM.set(D1, 0);
      Servo.setPosition(D2, 90); // Neutral position for the servo
  6. Joystick Control:
    • If you want to use a joystick, you can map the joystick inputs to these scripts. Ensure the joystick is configured to send commands to the Custom Movement Panel.
Alternative Solution
If using a joystick is not feasible, consider using the Mobile Interface Builder in ARC to create a custom control interface. This interface can have buttons or sliders for forward/reverse and left/right steering, which can trigger the respective scripts in the Custom Movement Panel.
Additional Tips
  • Testing: Test each script individually to ensure the motor and servo respond correctly.
  • Adjustments: You may need to adjust the PWM values and servo positions to match your specific hardware setup.
  • Documentation: Refer to the Custom Movement Panel Manual for more detailed information on scripting and configuration.
Feel free to ask if you need further assistance or clarification on any of these steps!
#2   — Edited
Is what you described a setup thats similar to a car? Where the wheels only go forward and backward, and the front wheels turn left and right?
the robot you have selected is an adventure bot. That doesn’t fit your description. Perhaps you meant to select the robot controller that you’re using. Can you tell us what robot controller you’re using and I’ll fix your post.
Germany
@df sures. Yes it is a modified adventurebot, it is like a RC car, iotiny,camera.Rear wheels go forward and reverse, one front wheel for steering with a servo in D4 . I use the Dual Hbridge W/PWM (L298N) port D2,D3 and D5 pwm. I connected only the right side for one motor
Would you describe it as looking like this from the top down? Where the rear wheels are on either side in the back, and there's a single front wheel that steers left/right by a servo.
I have some concerns about the viability of this configuration. I don't know its usefulness because it cannot pivot for tracking and navigating. It's a configuration you don't see with robotics for several reasons. The closest configuration to this in robotics would be having an unpowered castor front wheel and the rear wheels individually turn left/right to control the steering. A popular example would be any robot vacuum, similar to the iRobot Roomba.
However, if you have a specific use case for this configuration, let me know, and hopefully, we can make something work for additional features. Although getting a Movement Panel for it isn't very difficult, I'm more concerned about how other movement features will work with that configuration.
Germany
#5   — Edited
@dj sures  your drawing corresponds exactly to my wheel robot. I thought the configuration with only one motor and differential and one front wheel for steering could be easier to implement as 2 wheels individually turn left/right for steering. You have only one motor and one servo instead of 2 motors. A configuration in which the motors are very expensive, it would be an alternative.Duno if it makes sense to get a new Movement Panel which controls the forward/reverse/speed and the right/left steering (or something else) over a servo. The idea of front wheel steering came from a bicycle with JD on it. JD stands or sits on a 3 wheel robot platform and move the handlebar left or right. I have a JD beside, i have to built it and play easy rider:)
#6   — Edited
It’s absolutely possible to implement this, but as mentioned, it’s not a popular approach in robotics due to its lack of agility. Without a pivoting (rotating) movement mechanism, the system’s range of motion is limited, which significantly impacts agility. Robots relying solely on this type of movement may struggle to make tight turns or navigate complex environments efficiently. A more effective alternative is incorporating a pivoting mechanism or using designs inspired by robot vacuums, where a caster wheel in the front provides smooth directional changes and reduces strain on servos. That being said, you can make it work by using a Custom Movement Panel v2 and tailoring the scripts to your specific configuration, such as the ports, servo direction, and range.
Custom Movement Panel v2 manual is here: https://synthiam.com/Support/Skills/Movement-Panels/Custom-Movement-Panel-v2?id=21148
Here’s how you can structure your scripts for the different movement commands:
Forward Script
// Set the motor direction to forward
Digital.set(d0, true); // Enable forward direction on motor
Digital.set(d1, false); // Disable reverse direction on motor
// Calculate the speed for the pwm
// This maps the max specified speed (0-255) to a range for the PWM (0-100)
var topSpeed = Math.max(Movement.getSpeedLeft(), Movement.getSpeedRight());
var speed = Utility.map(topSpeed, 0, 255, 0, 100);
PWM.set(d2, speed);
// Calculate the speed difference between left and right speeds from the movement request
var diffSpeed = Movement.getSpeedLeft() - Movement.getSpeedRight();
// Map the speed difference to a servo steering angle
// The Utility.map function converts the difference to a range suitable for servo positioning
// This maps the max speed difference to a servo range of 1-180
var steeringAngle = Utility.map(diffSpeed, -255, 255, 1, 180);
// Set the servo position based on the calculated steering angle
Servo.setPosition(d3, steeringAngle);
Comments:
  • Ensure that d0, d1, 'd2', and d3 are assigned to the correct ports for motor control and servo.
  • Adjust the range 1 to 180 in the Utility.map function based on your servo's specific limits.
Reverse Script
// Set the motor direction to reverse
Digital.set(d0, false); // Disable forward direction on motor
Digital.set(d1, true); // Enable reverse direction on motor
// Calculate the speed for the PWM
PWM.set(d2, speed);
Comments:
  • Similar to the forward script, ensure the range in Utility.map matches your servo’s capabilities.
  • Verify that reversing the motor direction is correctly wired for your setup.
Stop Script
// Disable motor movement
Comments:
  • This script ensures the motor is stopped by deactivating both forward and reverse signals.
  • Test to confirm that the motor controller interprets this state as "stop" and not an error.
General Notes
  1. Test each script individually to ensure the expected behavior for your hardware.
  2. Consider adding error handling or feedback to identify issues during operation.
  3. If you’re using a non-standard servo or motor controller, double-check the specifications and adjust the scripts accordingly.
  4. Ensure proper power supply and connections to avoid hardware malfunctions.
Using these scripts, you can successfully implement a Movement Panel with servo control. However, this design has notable drawbacks, including reduced maneuverability due to the lack of pivoting motion and increased wear on the servos from the constant adjustments required to mimic a turning motion.
#7   — Edited
Let me add some context to the script as well.
In ARC, there is a movement manager who controls a Movement Panel in your project. When any robot skill requests to "move forward," the left and right wheel speed is also specified. That is how you can have a slight left or slight right forward motion. See the image below...
So what you'd be doing is only able to use the Forward, Reverse, and Stop movements. You cannot use "left" or "right". The forward and reverse will have slight left, slight right, etc. That's done by subtracting the specified speeds for the left and right to produce a positive or negative differential. That value is mapped to a servo angle for steering the front wheel.
The custom Movement Panel v2 is here: https://synthiam.com/Support/Skills/Movement-Panels/Custom-Movement-Panel-v2?id=21148
Any luck with getting this to work? The angle of steering and max speed might require some tweaks to the Utility.map parameters, but it should work fine
