HTTP Server icon HTTP Server — Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution. Try it →
no port v0 to choose
No Port V0 To Choose
hi
i see no option to choose port v0 in servo settings?
JD Humanoid by EZ-Robot
Lewansoul Servo by LewanSoul
Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation.
#1   — Edited
  1. Do LewanSoul bus servos allow an ID of 0?
  2. You have JD humanoid selected as the product. Are you adding a Lewansoul bus servo to an EZ-Robot JD Humanoid? Or did you mean to select a different product for this question? Such as EZ-Robot EZ-B v4 or Arduino Uno, etc...
#2   — Edited
According to the LX-16A Bus servo User Manual... There is no ID #0. What are you attempting to use ID #0 for?
Quote:
2.ID number set Each servo can set the ID number for the identification of the servo. The servo ID defaults to 1 and can be modified by yourself. The controller communicates with the servo in a single bus mode and the communication baud rate is 115200. The user can assign an ID number to each servo, and the command from the controller contains the ID information. Only the servos that match the ID number can receive this instruction and follow the instructions to execute the action
dj
i am trying to make a jd with lewansoul servo's.
thank you
The manual for lewansoul servos will be useful
