Neopixel Ring icon Neopixel Ring — ARC UI for onboard computers to control NeoPixel rings via serial: test/run patterns, preview and copy Arduino serial commands, includes sample code. Try it →
The FlashForge Create dual head printer has been upgraded with a firmware flash called Sailfish. There are details on how to do the flash on the Google FlashForge forum. I upgraded the Heated bottom plate by adding a 6 x 10 inch borosilicate glass plate 1/4 inch thick. Used 1/8 inch diamond drill bit to cut the mounting holes so that the stock HPB mounts could be used.
Autodesk 123D Make is the 3D program I use for building the prints I use.
I use Makerware and ReplicatorG for slicing the 3D prints.
The HPB platform is leveled by a manual process using the 4 spring loaded screws that mount the plate.
