Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
Quick Question Regarding Camera
so another probably noob question here but, i wanna put the camera i got with my ez b in the robot and control its on/off etc from the ez board, so question is as the camera obviously has a push switch on the back and a built in battery how do i connect the camera to the ez b, i presume i use a d port for the power but how does that work regarding the on/off switch ? can anyone provide me with a connection diagram for this and also the sparkfun h bridge ? im a little confused as to why i need 4 inputs into the h bridge ? and what each one is for, please bear with me here im new to this im used to basic stamp which uses servos mainly, thanks in advance, (by the way its the camera that you can but of the ez b website the wireless one)
Regards kurt
Hi Pacomms
Another Robot builder in the UK nice))
Check out this thread for camera
Click Here
Then you switch on the camera by say turning on the Digital Port in a startup script
and this for the Hbridge
Click Here
