Ubtech Alpha 1 Bluetooth icon Ubtech Alpha 1 Bluetooth — Bluetooth control for UBTech Alpha1 servos via ARC: map Vx to servo IDs, enable servos, and integrate with ARC movement & LEDs. Try it →
Use the bit builder to add designs to the library. Then use the 3d designer to add your designs to the robot.
ah yes.you have to fil in all details and houres. i have to adjust the houres  later. tomorow i start making the turning waist for big servo HDD
thanks dj
that will be neat to see! A turning waist will be cool
there is allreddy a turning waist with a low profile servo. see below this topic.
turning waist
