hi anyone
when i open ARC i cant see connection number 0 ? ive looked in the settings , no luck .
Irobot Roomba Movement Panel
— Control Roomba/Create via ARC: drive, stream sensors, read encoders, configure COM/HW UART, and send pose to NMS for mapping/navigation.
Hello Nomad_6R,
If you're having trouble seeing connection number 0 in ARC, it could be due to a few reasons.
Firstly, ensure that your JD Humanoid is powered on and connected to your computer. You can do this by checking the WiFi connection. The JD Humanoid connects to your computer via WiFi, so make sure it's connected to the same network as your computer.
If your JD Humanoid is connected and powered on but you still can't see the connection, try restarting ARC. Sometimes, a simple restart can solve the issue.
If you're still having trouble, you might want to check out the support section on the Synthiam website. There are many helpful articles and tutorials that can guide you through the process of connecting your JD Humanoid to ARC.
Remember, you can always ask for help here if you're still having trouble. We're here to help!
@athena
no sucses with reboot pc . also resetting ezbv4 no luck there . restart ARC also no sucses .
I'm sorry to hear that you're still having trouble, Nomad_6R.
If you've tried all the basic troubleshooting steps and still can't see connection number 0 in ARC, it might be a more complex issue.
Here are a few more things you can try:
Make sure your JD Humanoid's firmware is up to date. You can find instructions on how to update the firmware in the support section on the Synthiam website.
Try connecting to a different network. Sometimes, network issues can prevent ARC from recognizing your JD Humanoid.
If you're using a firewall or antivirus software, make sure it's not blocking ARC. You might need to add ARC to your firewall's list of allowed programs.
If none of these steps work, it might be best to reach out to Synthiam's support team directly. They can help you troubleshoot the issue and get your JD Humanoid connected to ARC.
hi
pc is updated and chrome .stil no sucses . it looks like the error is comming from the factory .
@athena
whats the latest ARC version ?
update
the number is 192.168.0.251 .this is the correct number . all is fine on pc still no sucses . i have the frimwire 23.06.9.0 is this correct ?
Hello Nomad_6R,
The latest version of ARC is always available on the Synthiam website. You can download it directly from there to ensure you have the most recent version.
As for the firmware, the latest version is 2021.06.23.00. If you have an older version, I recommend updating it. You can find instructions on how to update the firmware in the support section on the Synthiam website.
If you've updated both ARC and the firmware and you're still having trouble, it might be best to reach out to Synthiam's support team directly. They can help you troubleshoot the issue and get your JD Humanoid connected to ARC.
@athena
are you sure the latest version is 2021.06.23.00 ? cause i see 2023.06.09.00 ?
I apologize for the confusion, Nomad_6R. The latest firmware version is indeed 2023.06.09.00. I made a mistake in my previous message. Please ensure your JD Humanoid is updated to this version. If you're still having issues after updating, it would be best to reach out to Synthiam's support team directly for further assistance.
