Rubik's Cube Solving Robot icon Rubik's Cube Solving Robot — Control a custom ARC robot to manipulate and solve a Rubik's Cube using calibrated arms and grippers; integrates with Thingiverse build. Try it →
scripts, add java script
Scripts, Add Java Script
Can you please advise?
I went to scripts, then "add" JavaScript, clicked on the gear icon this is what happened:
Clearing compiled cache... Error editing javascript config: System.TypeLoadException: Could not load type 'EZ_Builder.UCForms.UC.UCVariablePicker' from assembly 'EZ-Builder, Version=2015.8.9.0, Culture=neutral, PublicKeyToken=c3a3457c97d352d9'. at Javascript.FormConfig.InitializeComponent() at Javascript.FormConfig..ctor(PluginV1 cf) in C:\My Documents\SVN\Developer - Controls\Javascript\Javascript\FormConfig.cs:line 20 at Javascript.FormMain.ucConfigurationButton1_Click(Object sender, EventArgs e) in C:\My Documents\SVN\Developer - Controls\Javascript\Javascript\FormMain.cs:line 126
Ang
Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent.
Manage and execute multiple scripts in a single Script Manager using ControlCommand(), with Control Details showing available commands.
Script by Synthiam
Real-time EZ-Script console for ARC: enter and execute single-line commands, view output, clear display, and recall history with UP/DOWN.
Javascript is built into the script editor. You do not "add javascript". If you're attempting to add javascript, it's because you're adding a deprecated plugin. Ignore your javascript plugin and simply use the script editor as before.
I understand that, just thought there was something else, thanks again
