BN-880 GPS Compass icon BN-880 GPS Compass — Standalone autonomous navigation using Beitian BN-880 GPS/Compass with real-time map waypointing and offline map caching; requires Arduino. Try it →
Small Change In Blockly
I'd like to request a small change in Blockly to fix the Add Comment. I figured out why ARC does not like this feature. If you look in the Javascript after you put comments on the Blockly code you will see that it is placing a # instead of a //  which would probably work with typical Javascript but not so much with ARC.     On a different note wondering when do you think the rollout for ARCX will be? Thanks
We’ve added this fix to Blockly to use // as the comment. Thanks for letting us know! It will be included in the next release
Teamwork, this will save future robot builders a lot of time. Having the ability to comment what each D6 or V31 etc will make it much more efficient. I think that I figured out another feature in Blockly that was locking up and not working properly. Want to verify and will get back with you.
