Midi Control icon Midi Control — MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes. Try it →
Why didnt you just connect the speaker to the EZB? To do so simply connect two wires to the speaker, then connect the other two ends to the signal and ground on a digital pin on the EZB.
Netherlands
Twitter YouTube
If you do that, you will only be able to play simple notes on it, TXT
Oh, my bad. Never mind.
