Com Port Manager icon Com Port Manager — Displays local PC COM/Serial ports opened by scripts, showing open/closed status (no communication logs); not the EZ-B UART. Try it →
strange behavior servo
Strange Behavior Servo
i notest a strange behavior when using window horizontal servo. when i check the invert direction box.i can move the servo lower or higher, but when i let go my mouse button the numbers go's automatic back up. excample i set the servo to 40 degree,let go mous button, degree go's back up to higher 100 degree?
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Horizontal Servo by Synthiam
Mouse-drag horizontal servo control with configurable min/max limits, center/release functions, multi-servo mirroring and direction invert.
i made a video so you can see what i mean.
That's been a thing with that silly horizontal or vertical servo control for a few years. I'll make a patch to fix it in a future release. However, in the meantime don't set Invert on the horizontal or vertical servo control.
dj
okay got it.thank you
Ha yah - the reason it never received much attention is because the manual servo controls (horizontal/vertical) are never inverted because there's no real need to do so. So it's just kinda been a thing everyone's accepted lol
then i will eccept it too.xDlol
for fun, i added the update to the latest BETA 2019.12.09.02 if you wanna download it:D
#7   — Edited
it works perfect .and you did that so fast.
thank you
