Debug icon Debug — Central ARC debug window routing logs; shows UTC date/time, Windows/ARC/skill/hardware info, version/settings, with copy and clear. Try it →
Resolved Resolved by Athena!
Voltage Regulator Getting Very Hot
hi i hope i can ask this question here . i use the HITEC 6 volt big servo's for the inmoove . i notest the regulators getting very hot very rapidly .  can i use the 6volt servo's with the 7.4 volt batterie without the 5 voltinline regulator ?
thanks
#9   — Edited
Hi Nomad, Sounds like you're drawing more amperage to run your servo then your voltage regulator and provide. There's a good chance you're going to burn it out. The servo you're running pulls up to 6 amps in a stall. You'll need a bigger boat (Jaws movie quote. LOL).
Here's my personal favorite. It's small, the output voltage is adjustable , input is variable up to 65 volts, has a 10amp MAX output and it's a switching regulator which means it will run cooler and be more efficient. It's a bit pricey and you'll also needs additional hardware to adjust the voltage through your computer but it's worth every cent. It's has 3 wires on the output side. You'll only need the two voltage wires so cut off ant tape the third one.
Castle Creations CC Bec 10A 6S Switching Regulator and programing kit:
Castle Creations Bec
Castle Creations Castle Link USB Programming Adapter
Since this is for an InMoov, you might want a 5v power supply with high amperage. Most people use that rather than batteries because there are so many servos.
DJ is dead on with his recommendation of using a 5 volt power supply with a high amp rating to run all your servos. As long as all your servos can run properly at 5 volts. Even though your hitec hs-805bb servo is rated at 6 volts (max) it will run nicely at 5 volts. It's rated to run between 4.8 - 6.0 Volts. When run at the lower end of the voltage range your servo will have less torque. This may not be an issue though.
hi averyone
robohappy i have allreddy bought all the servo's gail recomended . but i will have a look . thank you for the link .
hi dave
yeach one servo just dont move .  the voltage regulator will burn out for sure.
hi dj
a 5 volt power supply , you mean one that is plugged in a wallsocket ?
thank all
