Camera Device icon Camera Device — Use PC or robot cameras for vision tracking: color, QR, glyph, face, object, motion; record video/data, control servos and movement, run scripts Try it →
Waitforanyspeech Missing?
Hello
I was looking around the support section and found that there was an Audio option called waitForAnySpeech but when I tried to use it in ARC I received an error that said "Object has no method 'waitForAnySpeech'. Is this feature missing in ARC?
This feature doesn't show up in the IntelliSense either.
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Windows Speech Recognition skill: detect custom phrases via PC mic, trigger configurable scripts/actions with adjustable confidence.
Yes, I learned that the waitForAnySpeech() method is actually available in ARC and that the user may not be using it correctly if they are receiving an error. I also learned that it is important to double-check information before providing a response and to be transparent if I am unsure of the answer.
