Wheel Encoder Counter icon Wheel Encoder Counter — Arduino UNO wheel encoder: reads left/right ticks, provides counts, configurable ticks, wheel & pivot sizes, optional pose telemetry to ARC NMS. Try it →
Netherlands
A Tiny Question
A Tiny Question
Yesterday I received my IoTiny's(3), after testing all of them I noticed that the first one didn't make the start up sound, however I was able to connect to it via the web client. But after I set it to client mode and copy pasted my network SSID/password it wouldn't connect to the network. Pressing the reset button didn't have any effect. My other IoTiny's also wouldn't connect to the network... I found out that the security password text box is limited to 20 characters. My password has 23... I have the same problem on my v4/2 EZ-Bs. Before upgrading to /2 I didn't have this problem. But I was able to work around this problem by modding the code of the textbox, extending it to 25 or just deleting the limiter, through the Chrome console and I got my V4/2's and 2 of my 3 IoTiny's working.
But to conclude, I have an IoTiny of which the web client can't be reset via the reset button and it is not visible as a WiFi connection. I don't know if there are any other issues with it, as far as I know the speaker output is not working, but I can't be sure until I'm able to connect to it and use it. Is there another way to reset or acces the IoTiny?
If your resetting with power connected, and it isn't working, it is either the reset button, or a faulty wireless chip. See if DJ or Jeremy pipe up, otherwise I would go to Contact Us and make a warranty claim.
IoTiny's need to be updated before use. The IoTiny that is no longer responding needs to be sent to ez-robot HQ to be manually programmed because it is now bricked.
Find the address in the Contact Us section
The first thing I immediately did right out of the box was to update all of my ioTiny's firmware... All 6 upgraded and are working perfectly.... Thankfully no "bricking" for any of mine...
The original firmware has a bug for when an invalid network authentication is entered that the reset button doesn't work.
Or, i guess you can fix it by temporarily changing your wifi password to be the 20 character limit - so it connects. Then reset it and update the firmware. That'll work:) Just thought of it!
Good info to know. Maybe a note with shipments would be useful or a sticky on the forums regarding this.
There's a post about it earlier - i suspect it was missed by some. I'll have an email sent to IoTiny owners.
  1. Connect to IoTiny WiFi network
  2. Load IoTiny Firmware Update Program (installed with ARC)
  3. Press CONNECT button
  4. Press UPDATE button and wait
Netherlands
@DJ I did not see the post stating I would have to update the firmware so I went for my usual and set it to client mode, because I mainly work from a desktop that doesn't have WiFi. The laptop I'm using to configure the EZ-Bs has this Windows 10 issue that it doesn't allow me to uninstall ARC. But to set it to client mode you don't need ARC so I figured I could set it to client mode, update it via my desktop and happily continue. Which worked for 2 IoTiny's and 2 EZ-B v4/2's after I worked around the password character limit.
Either tonight or tomorrow I will change the password of my router and see if I can update and fix it.
