EZ-Script Console icon EZ-Script Console — Real-time EZ-Script console for ARC: enter and execute single-line commands, view output, clear display, and recall history with UP/DOWN. Try it →
Netherlands
A Tiny Question
A Tiny Question
Yesterday I received my IoTiny's(3), after testing all of them I noticed that the first one didn't make the start up sound, however I was able to connect to it via the web client. But after I set it to client mode and copy pasted my network SSID/password it wouldn't connect to the network. Pressing the reset button didn't have any effect. My other IoTiny's also wouldn't connect to the network... I found out that the security password text box is limited to 20 characters. My password has 23... I have the same problem on my v4/2 EZ-Bs. Before upgrading to /2 I didn't have this problem. But I was able to work around this problem by modding the code of the textbox, extending it to 25 or just deleting the limiter, through the Chrome console and I got my V4/2's and 2 of my 3 IoTiny's working.
But to conclude, I have an IoTiny of which the web client can't be reset via the reset button and it is not visible as a WiFi connection. I don't know if there are any other issues with it, as far as I know the speaker output is not working, but I can't be sure until I'm able to connect to it and use it. Is there another way to reset or acces the IoTiny?
@budel0 Slightly off topic, but have we tried to troubleshoot your Windows 10 issue? Is it a machine from work and giving you an administrative rights issue? If so, I might have a solution. Let me know what error you are getting when you try to install, and I might be able to help you figure out the issue.
Thanks DJ. I remember that thread now. However live is full of distractions and I lost track in my mind. Not unusual these days. I'm glad I have this info now and will update my little guys this weekend. ;)
Upgraded mine this AM. All went smoothly. Easy Peasy!
Will do my V4/2 upgrades tonight for big R2.
@Lumpy That's a lot of iOTinys...:D... I snagged myself 6 of them. However as soon as more become available I plan on buying a boat load more....:)
Netherlands
@DJ Unfortunatly no luck after changing the WiFi password, I tried serveral times without any results. I even tried with different versions of the cut-off password, yielding the same result. Are there other possiblities?
@TheTechGuru I mainly use the laptop for work, but it's mine personally, I have all the rights etc. But it's the "windows 10 uninstall a program problem where it'll ask for a non existing .msi file", the same happens when I try to uninstall it by installing the newer version. The internet told me to solve it by deleting it through the Regedit, but that didn't have any effect. I haven't had the time to try other possible solutions, but if you have any other suggestions to solve this problem I will greatly appreciate them.
I'll do some research to see if I hve any suggestions.
#16
@Lumpy,
The new /2 comm boards when installed on old v4, also need a firmware update? I wish this forum has stickies.
