Camera Variable Overlay icon Camera Variable Overlay — Overlay image packs onto camera feed and map images to control-variable ranges with auto/manual assignment, position and sizing options. Try it →
Austria
ARC
Hi I'm from Germany also have a EZ - Board V3 + and think it's really cool what you can do with it but unfortunately I have a big problem connecting to ARC . So I connect my bluetooth give 1234 and it connects to the PC but when I select the ARC the correct port the smaller of the two and click Connect comes an error see Screenshot what am I doing wrong that can not be true , I try it already had days I'm very technically gifted eigendlich but that part will simply not connect other Bluetooth dongles have already try with the laptop it does not connect This message comes is the port that right ez - b flashes blue and red LED:
Attempting connection on COM50 Connection Failed: System.TimeoutException: Timeout bei Schreibvorgang überschritten. bei System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout) bei System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count) bei EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected
Austria
So now have the original driver downloaded for bluetooth dongle and and there is software here with whom I have now a connection to the red LED lights get bluetooth down permanently but blue flashes Imer yet and whom I now going to connect com 2 comes back error message see screenshot
Austria
I can see here , there is no help or support for the V3 , I have noticed there is only support for the V4 who owns an old V3 lost . In ezrobot forum you will find nothing about V3 or bluetooth connection problems ! I do a lot with the PC in my home is all crosslinkable with TV satellite receiver Linux with custom firmware , have PS3 , mobile phones FLASHE an own server , encode different things on my car with NCS expert and so on. But the connection with the ARC I do not get out . That can not be that is it so complicated to connect the stupid software board with or has the software bugs and Problem solving correctly with the V3 but only with the V4 . The proposals were made ??here since I 'm already even come on it and have all been previously applied before I signed here unfortunately without success . mad mad mad mad mad
The ez-b V3 is not supported by Ez-robot, but the forum still answers questions on them. Your problem is unlike anything I have seen before. It could very well be that you fried the processor chip somehow and it no longer communicates with the pc, or the bluetooth module is messed up.
As for your statement about the lack of bluetooth problem help, a quick search of the forum will reveal many threads on the issue that have been resolved. No they may not be on the first page, but there are many answered forum posts.
What I would do next is:
  1. Reinstall ARC. First remove it, then install the latest version off the web using the complete install option.
  2. Re-seat the bluetooth module if not already done. As well, make sure nothing is connected to the ez-b.
  3. Delete the ez-robot device from your bluetooth and re-do the connection process.
Then we will look at what to do next.
Austria
  1. I've done several times already some old versions ARC tried to install more software completely.
  2. bluetooth module I have tested with multimeter as shown in the video pin 5 and pin 6 of the chip to the bluetooth module 0 ohms. have all pins examined by the bluetooth module to the motherboard connector on passage (contact) everything ok
  3. I once made already 100 bluetooth dongel with another Usb
What struck me when I blutooth briefly connected with windows settings associate comes and then only coupled it does not remain connected at gekoppel. One can not only connect disconnect and re-connect and re not connected when I got to the ARC the com port select them to combine then press the blue LED lights up continuously and then the message is (see photos in the first post) and danch It Begins flashing again so there is kontact but it does not connect dauehaft.
Have win10 64bit it may perhaps be due? no matching driver for the bluetooth usb dongel ? does anyone know who is the manufacturer of usb bluetooth dongel ? Then I can maybe download and install manuel driver for win10 64bit confused confused confused confused confused
#15
Have you tried updating the firmware?
Austria
#16
not going no connection
