Servo Speed icon Servo Speed — Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved. Try it →
Austria
ARC
Hi I'm from Germany also have a EZ - Board V3 + and think it's really cool what you can do with it but unfortunately I have a big problem connecting to ARC . So I connect my bluetooth give 1234 and it connects to the PC but when I select the ARC the correct port the smaller of the two and click Connect comes an error see Screenshot what am I doing wrong that can not be true , I try it already had days I'm very technically gifted eigendlich but that part will simply not connect other Bluetooth dongles have already try with the laptop it does not connect This message comes is the port that right ez - b flashes blue and red LED:
Attempting connection on COM50 Connection Failed: System.TimeoutException: Timeout bei Schreibvorgang überschritten. bei System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout) bei System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count) bei EZ_B.EZB.Connect(String hostname, Int32 baudRate) Disconnected
#17
I would look into the driver. Take a look at the bluetooth dongles maker and see if you can find the right driver. if you have one that lists no manufacturer, then it likely will just use the Microsoft "Generic Bluetooth" driver. try running that driver in a compatibility mode, or if your not using it currently, try installing it instead of the in use one.
Also, reinstalling the bluetooth driver is an option.
#18
Why did you use Com3 on the earlier screen shots and Com4 in the firmware update?
Did you try Com3 with firmware update?
Austria
#19
But I have already tried both ports of com 4 is but for firmware update or ? I've already written as a different USB Bluetooth dongel used there but very high com ports are shown me . Can one tell me who is the manufacturer of this usb bluetooth dongel is there is the ez robot board found ? Then I could download the driver from the manufacturer website and install manually .
Optimus I just want to clarify. You have in fact tried ALL com ports?
As for the dongle, it's a generic build. Search kns3620a2 Bluetooth to find all the available drivers. The generic Microsoft Bluetooth driver is the best.
Austria
#21
I can not believe it's finally amazing I already I lost all hope have already want to give it it's here my screenshot
Austria
#23
now I 've been trying to connect this christmas I have been despair . I have not changed the same settings , the same driver , have only an older version ARC withdrawn . It is the only old version I own which is from 11.14.2015 . With it works without problems all goes 've staked out and re- inserted several times everything and is still doing everything . The firmware update for the ez board I have done it all without problems ! I still can not believe it 's finally there . It was up to the new ARC software !
Now I always get the message that I should make an ARC update have now naturally fear again get no connection with the new version ARC .
#24
@Optimus Don't live in fear... buy an ezb4 and be happy:D
