Set Digital icon Set Digital — Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only. Try it →
Yes single RGB LEDs could work for each eye and a mouth if you have a tight form factor inside your robot's head, that's good idea.
i was just reading.does the bit have multiple colors?for the mout i have enouch, white ports.its the eyes .
so adres rgb is 0xA2 so next is 0xA3 ?
The blaster bit has all the colors of the Rainbow:).
If you wanted to use 3 sets of EZ-Robot RGB Eyes, you could use 0xA0, 0xA2, 0xA4, etc
jeremie
you teached me alot.thanks
