Having a problem reading adc
Using the following script
if (adc(adc0) > 10 ) servo(d1,29)
adc0 shows full 5.volts but no change in servo value ?
am I using incorrect commands ?
Sound Script
— Replaced by Sound Script (Speech Script) robot skill; see Synthiam's Speech Script support page.
Possibly fixed now with the latest version Here
@winstn60 Thanks for reply Downloaded latest version , but no success
the "wait" command works ok ?
Pat
latest update Works but is not reading values properly
confused
I've tested this and it works. What are you experiencing?
at present my script reads
voltage 5v on adc0 graph
but servo does not register in debug
same in <
getadc(adc0)
reads value ok
The documentation is incorrect. It is GetADC(adc0)
Thanks Dj
Sorry I may not be explaining it clearly
This is the script I entered
GetADC(adco) If (ADC(ADC0) > 5) Servo(d1, 29)
when I run this is the debug reply
Start GetADC(adc0) 134 If (ADC(ADC0) > 1) Done
as you can see adc value is 134 , Get command responds ok but " If " Statement does not
script two example
GetADC(adc) If (ADC(ADCO) < 1) servo(d1,29)
When I run this is the debug repy
Start GetADC(adco) 134 If (ADC(ADC0) < 1) servo(d1,29) Done
Get, responds with correct value , but " iF " statememt even though its not true , it moves the servo
Hope I have outlined it a little clearer
pat
Again, the script manual was incorrect for the IF condition. The syntax is
Get the latest ARC and notice the manual has been updated. The manual was incorrect. The proper command is GetADC().
Thank you Dj Dowloaded update and entered new commands all works very well. excellent
Take the remainder of the day off !
Ez-b is no 1
nothing comes near.
Pat
