EDU Activity Editor icon EDU Activity Editor — Design, edit and export structured Blockly-based lessons, groups and hints for ARC Lite Portable; supports rich HTML, images, JSON import/export. Try it →
Auto Position
when I set up my servos in the auto positioner they slowly move down the frame window until they are no longer there. It happens when I select any button for the frames or servo position. now I have to delete the auto positioner and restart it. when I add more servos I have to move them all back to the top of the window so they don't disappear? does any one else have the same issue? confused
I'm unsure what you mean. Can you provide a screenshot?
Screen shot one shows that I set up two servos ad selecting the idle frame.. screen shot two shows that when I select the walk frame, the servos move position down the screen and once they get to the bottom, they disappear.
@shamon ... I tried the same set up with three servos, test1,test2,test3 . I closed and opened the Auto Position 10x and found no downward drift?! was your observation a "time" event or open and closing?
They only move whenever I selected anything from the right menu in the AutoPosition Window . And it still happens even after the update today.
I have the same problem. I will make screen shots later.
:):):) stress J
no changes, press save.
check what I did, go back again, they move
repeat
all shifted down again.
stress stress stress stress j
I can't get it to do it either but I had a similar problem with the Mobile interface maker. I don't know the details but I THINK it has something to do with screen resolution. Im at 600x1900 and most examples I open seem to be too big and I have to move stuff around to get it all onto my screen properly. It may be nothing but, the only time I've had similar issues with other controls it was Screen Resolution. I do notice a jump when you toggle Port Edit mode. It may be related to that some how? Sorry that's all I can think of.
do any of you have the DPI or Text Size changed in windows?
I do have the text size and icons increased. My computer is a Sony Viao duo 11. The screen is 11 inches and if I don't increase the size than I have to squint to read any words lol.
