Kinect Xbox 360 Depth Mapping icon Kinect Xbox 360 Depth Mapping — Converts Xbox 360 Kinect depth frames into NMS obstacle scans for ARC path planning, SLAM, and obstacle avoidance. Try it →
Auto Position
when I set up my servos in the auto positioner they slowly move down the frame window until they are no longer there. It happens when I select any button for the frames or servo position. now I have to delete the auto positioner and restart it. when I add more servos I have to move them all back to the top of the window so they don't disappear? does any one else have the same issue? confused
yeah - I think that's what is causing it. Windows is really strange when text and icon size is increased. i'll look into it to see if there is a way to fix it. I've ran into that problem before - but the only solution was to not increase the size of the text. Let me see what I can find for you...
I took a look and think i may have a solution... I'll get you to try it in the next release
Thank you for looking into this, I will keep my fingers crossed:D
Thanks, look forward to the fix.
:):):):) J
Thank you the fix worked for me. :D
that fixed it.
:):):):) J
