Relative Servos icon Relative Servos — Synchronize servos by designating a master; slave servos mirror scaled (decimal/negative) positions with min/max limits and pause control Try it →
Hello,
We are seeking the specifications or datasheet for a camera compatible with the EZ-InMoov robot head. It appears that the original camera is not available for purchase, and we are considering alternatives that meet the required specifications. Could you provide guidance on this matter?
Thank you in advance for your assistance.
Best regards,
Satish
EZ-Inmoov Robot Head by EZ-Robot & Gael Langevin
EZ-InMoov Robot Head with Synthiam ARCx: face tracking, speech recognition, Talk Servo jaw motion and AI conversation
Servos 8
ADC 2
Digital 8
Camera Source (Usb) by Synthiam Inc.
Publishes a camera feed as a named ARCx video source for face tracking, object tracking, recording, and autonomous AI.
Hello Satish,
The EZ-InMoov Robot Head is designed to work seamlessly with the EZ-B Camera, which is included in the kit. However, if you need a replacement or an alternative, you can consider using a USB webcam that is compatible with ARC. Here are some steps and considerations for selecting a compatible camera:
  1. Compatibility: Ensure that the camera you choose is compatible with ARC. Most USB webcams should work, but it's always a good idea to check the specifications and ensure they support the necessary resolutions and frame rates for your application.
  2. Resolution and Frame Rate: Look for a camera that offers a good balance between resolution and frame rate. A 720p or 1080p camera with at least 30 frames per second is generally sufficient for most applications.
  3. Mounting: Consider how the camera will be mounted on the EZ-InMoov Robot Head. You may need to create or modify a mount to fit the new camera securely.
  4. Connection: Ensure that the camera can connect to your computer or the IoTiny controller via USB or another compatible interface.
  5. Testing: Once you have a camera, test it with ARC to ensure it functions correctly with the Camera Device skill. You can configure the camera settings within ARC to optimize performance.
If you need further assistance or have specific cameras in mind, feel free to share more details, and I can help you evaluate their compatibility with the EZ-InMoov Robot Head.
Best regards, Athena
For more information on the EZ-InMoov Robot Head, you can visit the EZ-InMoov Robot Head support page.
I do not see a USB port on the IoTiny controller. How do I then connect a USB camera to it? We would like to use the camera for robot eye color tracking.
Disclaimer: I toyed with the camera function very little and it was a long time ago. LOL, However:
The USB camera is plugged into your computer. The same computer that is running current versions Windows and ARC. I assume you want the camera mounted on the InMoov ? I don't know how the InMoov builders do it but that tells me that the computer needs to be mounted on the InMoov also. If you don't want the computer mounted on the InMoov I guess you could try to somehow mount a bluetooth camera on the robot and send a bluetooth signal to the computer.
Good luck.
The InMoov head is produced by ezrobot and the camera is available for purchase on their website. The camera for that kit is the standard ezrobot camera.
@Synthiam Support,
Yes, I am aware of the ezrobot. The issue is that they don't have any cameras or even the kits available for purchase and delivery anytime soon.
@Dave Schulpius: Thanks. Yes, the camera must be mounted on the InMoov. I connect to the InMoov using wifi. And then, I connect to it using the ARC pro interface. Are you saying that I can buy a USB camera and then plug it into the same computer where ARC is running and then potentially add the camera as a new camera device in ARC and use it for color tracking? Thanks in advance.
You could buy the EZB camera from EZ-Robot, It is available, and just remove the outer enclose to place the camera PCB inside the InMoov head. The camera then plugs directly into the IO-Tiny (no USB port required) if that is what you are looking for.
Yeah you can use an usb camera but it must connect to the computer.
@RoboHappy
I got an official response from EZ-ROBOT that they do NOT have any available to buy at this time and that  the camera module has been discontinued.
