Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Thanks for showing me those. Is there a manual for it? Also, is it small? the robot is only 16 in. tall, and the body is fairly small. Thanks!
Those first ones are the ones i need. One more question. How do those connect?
According to the website, the regulators have solder points that headers can be soldered to or terminals blocks can be soldered in and then wires can be inserted into the blocks and screws hold the wires by tightening them. Both are included with the regulator.
Oh. Well, if I have to get those, I will. Is there a 6v regulator where it just snaps right into the servo port and the wire can just plug into it? That is, if regulators like that even exist
#15
What im trying to find is a regulator that doesn't need to be soldered in. Just a regulator that snaps into the servo port, and then the wire can plug into wire connected to the servo.
